ARSVG
- 21.01.2024
- 14
- 8
- RFT Meister
Thank you. I need NVM.EED to unlock main board.
Hey, unfortunately I can't write to you privately and wanted to ask if you could help me. I have the same problem, the Phillips logo shows up then it goes away and ambilight is on.Remote control responds so standby flashes when button is pressed. I wrote a post somewhere else that said you could give me a tip on how to unlock it. I would be very grateful for the help.Hi,
Thank you everybody for your help.
It's sorted out.
Obviously I can't give tik-tak full dump.
It's need to clear from owner's personal dates.
It's my time.
But if you need some areas without of the keys sent me request with addresses.
Good luck!
Hi,Hey, unfortunately I can't write to you privately and wanted to ask if you could help me. I have the same problem, the Phillips logo shows up then it goes away and ambilight is on.Remote control responds so standby flashes when button is pressed. I wrote a post somewhere else that said you could give me a tip on how to unlock it. I would be very grateful for the help.
In my case - unlocking.So what was the solution here exactly?
Hello, can you tell me, how do you unlock? My 55oled855 has a broken 24 v line in the PSU. I changed the PSU and now my Philips logo come on. After a few seconds the logo leave and the led in front Beginns flashing. I have the upgrsde_loader.upg from Philips direct. It come "upgrade in process" but after 20 minutes, the led is also flashing. The bootlog say Tcon error. I think the Tcon oder Mainboard is blocked bei software, because the 24 v fault bevore.In my case - unlocking.
Vielen Dank Thomas, jetzt rennt die Kiste wieder !LG Thomas
