es handelt sich dabei um ein 400 Watt starkes Industrie Netzteil.
Technische Daten
Type O/P 1 O/P 2 O/P 3 O/P 4
MML series
200/12 5-15V (12) 12A - - -
200/24 12-28V (24) 7A - - -
200/T 2-6V (5) 25A 5-15V (12)* 5-15V (12)*
400/24 12-28V (24) 15A - - -
400/12 5-15V (12) 24A - - -
400/T 2-6V (5) 60A 5-15V (12) 12A 5-15V (12) 12A -
400/Q 2-6V (5) 60A 5-15V (12) 12A 5-15V (12) 12A 12-28V (24) 7A
600/24 12-28V (24) 25A - - -
OMS series
1000/12 11·5-16V (12) 83A - - -
1000/24 23-30V (24) 41A - - -
1000/48 45-60V (4
21A - - -
Factory preset voltages shown in brackets
* O/P 2 and O/P 3 current collectively 6A
Note: Total of output loads must not exceed rating of unit
Input:
MML 200/400 180 to 264V a.c. (on 230V a.c. nom.)
90 to 132V a.c. (on 115V a.c. nom)
Link selectable, factory set to 230V a.c.
all other models 85 to 265V a.c. (universal input)
Frequency 47-63Hz
Minimum load 0A on all outputs
Load regulation 0·1% typical for 0-100% load change
Line regulation 0·1% at ±20% of nominal mains
Noise and ripple 50mV or 1% (whichever is greater)
Operating temp. 0 to +70°C (derate at 2·5%/°C above 50°C)
dimensions
Dimensions H. W. L. Wt (kg)
MML 200/12 64·5 127 143 1·1
MML 200/24 64·5 127 143 1·1
MML 200/T 64·5 127 166 1·3
MML 400/24 64·5 127 212 1·6
MML 400/12 64·5 127 212 1·6
MML 400/T 64·5 127 257 2·0
MML 400/Q 64·5 127 280 2·2
MML 600/24 64·5 127 303 2·75
OMS 1000 units 80 203 304 4·75
Falls Du mehr wissen willst musst Du einfach mal Googeln.
