N
netphoton
- 18.06.2007
- 16
Hersteller: Nokia
Typenbezeichnung: Nokia Kabel Avia500 2xI
Schaltplan vorhanden: Ja
Dein Wissensstand: Einsteiger
ich habe hier eine Nokia Kabel die beim Booten in den Standby geht.
Bootlog:
## Booting image at 00100000 ...
Image Name: dbox2
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 650813 Bytes = 635.6 kB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
IDE-Treiber werden geladen...
Detected STB:
Vendor: Nokia
Model: D-BOX2
HD wird gemounted...
mount: Mounting /dev/ide/host0/bus0/target0/lun0/part2 on /tmp/hdd failed: No such file or directory
/dev/ide/host0/bus0/target0/lun0/disc: No such file or directory
insmod: init_module: avia_av: Input/output error
insmod: unresolved symbol avia_av_set_stc
insmod: unresolved symbol avia_gt_gv_copyarea
insmod: unresolved symbol avia_gt_gv_show
insmod: unresolved symbol avia_gt_gv_get_clut
insmod: unresolved symbol avia_gt_gv_get_blevel
insmod: unresolved symbol avia_gt_gv_set_input_size
insmod: unresolved symbol avia_gt_gv_set_pos
insmod: unresolved symbol avia_gt_gv_hide
insmod: unresolved symbol avia_gt_get_info
insmod: unresolved symbol avia_gt_gv_set_size
insmod: unresolved symbol avia_gt_gv_set_input_mode
insmod: unresolved symbol avia_gt_gv_set_clut
insmod: unresolved symbol avia_gt_gv_set_blevel
insmod: unresolved symbol avia_gt_gv_get_info
insmod: unresolved symbol avia_gt_ir_exit
insmod: unresolved symbol avia_gt_ir_receive_pulse
insmod: unresolved symbol avia_gt_ir_receive_data
insmod: unresolved symbol avia_gt_ir_get_rx_buffer_write_position
insmod: unresolved symbol avia_gt_ir_send_buffer
insmod: unresolved symbol avia_gt_ir_queue_pulse
insmod: unresolved symbol avia_gt_ir_init
insmod: unresolved symbol avia_gt_ir_set_duty_cycle
insmod: unresolved symbol avia_gt_ir_set_frequency
insmod: unresolved symbol avia_gt_ir_get_rx_buffer_read_position
insmod: unresolved symbol avia_av_set_sample_rate
insmod: unresolved symbol avia_gt_pcm_play_buffer
insmod: unresolved symbol avia_gt_pcm_stop
insmod: unresolved symbol avia_gt_pcm_set_signed
insmod: unresolved symbol avia_gt_pcm_set_endian
insmod: unresolved symbol avia_gt_pcm_set_rate
insmod: unresolved symbol avia_gt_pcm_set_width
insmod: unresolved symbol avia_gt_pcm_poll
insmod: unresolved symbol avia_gt_pcm_set_channels
insmod: unresolved symbol avia_av_get_sample_rate
insmod: unresolved symbol avia_gt_pcm_set_pcm_attenuation
insmod: unresolved symbol avia_gt_pcm_get_block_size
insmod: unresolved symbol avia_gt_pig_show
insmod: unresolved symbol avia_gt_pig_set_stack
insmod: unresolved symbol avia_gt_pig_set_size
insmod: unresolved symbol avia_gt_pig_set_pos
insmod: unresolved symbol avia_gt_pig_hide
insmod: unresolved symbol avia_av_stream_type_set
insmod: unresolved symbol avia_av_register_video_event_handler
insmod: unresolved symbol avia_av_set_audio_attenuation
insmod: unresolved symbol avia_av_write
insmod: unresolved symbol avia_av_pid_set
insmod: unresolved symbol avia_av_audio_pts_to_stc
insmod: unresolved symbol avia_gt_dmx_queue_write
insmod: unresolved symbol avia_gt_dmx_enable_clip_mode
insmod: unresolved symbol avia_gt_dmx_disable_clip_mode
insmod: unresolved symbol avia_av_play_state_set_video
insmod: unresolved symbol avia_av_unregister_video_event_handler
insmod: unresolved symbol avia_av_get_video_size
insmod: unresolved symbol avia_av_play_state_set_audio
insmod: unresolved symbol avia_av_read
insmod: unresolved symbol avia_gt_pcm_set_mpeg_attenuation
insmod: unresolved symbol avia_av_new_audio_config
insmod: unresolved symbol avia_av_set_video_system
insmod: unresolved symbol avia_av_bypass_mode_set
insmod: unresolved symbol avia_av_sync_mode_set
insmod: unresolved symbol avia_gt_dmx_queue_nr_get_bytes_free
insmod: unresolved symbol avia_gt_dmx_get_ucode_info
insmod: unresolved symbol avia_gt_vbi_start
insmod: unresolved symbol avia_gt_dmx_queue_reset
insmod: unresolved symbol avia_av_napi_decoder_stop
insmod: unresolved symbol avia_gt_dmx_queue_stop
insmod: unresolved symbol avia_gt_dmx_queue_irq_enable
insmod: unresolved symbol avia_gt_dmx_set_pcr_pid
insmod: unresolved symbol avia_gt_vbi_stop
insmod: unresolved symbol avia_gt_dmx_alloc_queue_teletext
insmod: unresolved symbol avia_gt_dmx_disable_framer
insmod: unresolved symbol avia_av_napi_decoder_start
insmod: unresolved symbol avia_gt_dmx_queue_start
insmod: unresolved symbol avia_gt_dmx_tap
insmod: unresolved symbol avia_gt_dmx_enable_framer
insmod: unresolved symbol avia_gt_dmx_alloc_queue_video
insmod: unresolved symbol avia_gt_dmx_free_queue
insmod: unresolved symbol avia_gt_dmx_alloc_queue_audio
insmod: unresolved symbol avia_gt_dmx_alloc_queue_user
insmod: unresolved symbol avia_gt_dmx_get_stc
insmod: unresolved symbol avia_gt_accel_crc32
insmod: unresolved symbol avia_gt_set_playback_mode
insmod: unresolved symbol avia_gt_get_playback_mode
insmod: unresolved symbol avia_av_is500
insmod: unresolved symbol avia_av_cmd
Please press Enter to activate this console. rm: cannot remove `/var/etc/.slot0_start': No such file or directory
rm: cannot remove `/var/etc/.slot1_start': No such file or directory
rm: cannot remove `/var/etc/.slot_com': No such file or directory
rm: cannot remove `/var/etc/.slot_multi': No such file or directory
rm: cannot remove `/var/etc/.com_betad': No such file or directory
rm: cannot remove `/var/etc/.multi_betad': No such file or directory
[CBasicClient] connect failed.
/tmp/sectionsd.sock: No such file or directory
TimeOut von 10 Sekunden ueberschritten!
Festplatte nicht bzw. zu spaet gemountet!
$Id: zapit.cpp,v 1.395 2007/03/17 21:34:22 houdini, patched by GLJ-Team (JohnDoe) Exp $
[zapit] PMT update enabled
[getservices] /var/tuxbox/config/zapit/myservices.xml found.
/tmp/currentservices.xml: No such file or directory
[audio.cpp:CAudio] /dev/dvb/adapter0/audio0: No such file or directory
[video.cpp:CVideo] /dev/dvb/adapter0/video0: No such file or directory
[aviaext.cpp:CAViAext] /dev/dbox/aviaEXT: No such file or directory
$Id: controld.cpp,v 1.124 2006/06/27 10:21:59 barf Exp $
[controld] Boxtype detected: (1, Nokia D-BOX2)
[controld] /dev/dvb/adapter0/video0: No such file or directory
[controld]: ROUTEVIDEO v1 = 4 a1 = 1 v2 = 2 a2 = 1 v3 = 0 a3 = 1 fblk=0
[controld] setting VideoFormat to auto
[nhttpd] Neutrino HTTP-Server starting......Patched GLJ-Team (JohnDoe)
[LCDFONT] initializing core...
[LCDFONT] adding font /share/fonts/micron.ttf...OK (Micron/Regular)
[LCDFONT] adding font /share/fonts/micron_bold.ttf...OK (Micron/Bold)
[LCDFONT] adding font /share/fonts/pakenham.ttf...OK (Pakenham/Regular)
[LCDFONT] Intializing font cache...
$Id: sectionsd.cpp,v 1.237 2007/03/29 15:43:32 mws Exp $
[sectionsd] Caching max 2500 events
[sectionsd] Caching 1 days
[sectionsd] Events are old 60min after their end time
/var/tuxbox/config/zapit/epgfilter.xml: No such file or directory
/var/tuxbox/config/mybouquets.xml: No such file or directory
[sectionsd] getUTC: open: No such file or directory
[sectionsd] open dmx: No such file or directory
/tmp/neutrino: /lib/libpng12.so.0: no version information available (required by /tmp/neutrin
[neutrino] frameBuffer Instance created
/dev/fb/0: No such file or directory
framebuffer not available.
FBIOPUT_VSCREENINFO: Bad file descriptor
FBIOGET_FSCREENINFO: Bad file descriptor
[neutrino] Error while setting framebuffer mode
ping: http://www.google.com: Host name lookup failure
zapit shot down
lastChannelRadio2: 0
lastChannelTV2: 207
Waiting for controld (max. 9 seconds)
Waiting for controld (max. 8 seconds)
Waiting for controld (max. 7 seconds)
Waiting for controld (max. 6 seconds)
Waiting for controld (max. 5 seconds)
Waiting for controld (max. 4 seconds)
Waiting for controld (max. 3 seconds)
Waiting for controld (max. 2 seconds)
Waiting for controld (max. 1 seconds)
Ist hier der Avia defekt?
Bootlog:
Image Name: dbox2
Detected STB:
Vendor: Nokia
Model: D-BOX2
zapit shot down
lastChannelTV2: 207
