Grundig 40 VLE8042
Diskutiere Grundig 40 VLE8042 im Forum Grundig TV - Softwareprobleme im Bereich Reparatur von LCD Plasma Fernsehern sowie Beamer - Hi thommyX , sorry, but i have the same problem which i read in forums with Grundig 40 VLE8042. I find the softwere SX_NDLNA_50_737_3.ZIP, and...
dsp_83
03.03.2020
7
Hi thommyX , sorry, but i have the same problem which i read in forums with Grundig 40 VLE8042. I find the softwere SX_NDLNA_50_737_3.ZIP, and install it. The TV started, but when I turned it off and try to turned on it was the same thing. It can't start. Tryed to install the software again but it can't. Can you send me the best software if is not problem to you. My email is **********. Thank you for .
9.213
660
Panelcode SS17 or SS20???
dsp_83
03.03.2020
7
dsp_83
03.03.2020
7
Hi ThommyX , Is there any chanse to send me the best software?
9.213
660
send
dsp_83
03.03.2020
7
Moement
20.03.2020
auch mein Grundig 40 VLE 8042 S (056D40-SS17) will nicht mehr anspringen. Die LED blinkt und nichts tut sich.
Ich bin nach der Anleitung für die SW Installation per USB Stick vorgegangen ("Grundig Service Anleitung Blinkcode"), bin mir aber nicht ganz sicher, ob ich alles richtig gemacht habe. Die Installation lief auf jeden Fall durch aber leider keine Änderung.
Verwende ich vllt. die falsche Datei? SX_NDLNA_50_737_3.ZIP
Danke im Voraus!
Moement
dsp_83
03.03.2020
7
Hi ThommyX, sorry that i loose your time again with my problem (I see that it's not only my problem :) ) , but it doesn't work after install the software which you sent me. I will try to explane the situation. This software was installing faster than other softwares which I read in forums and installed. When tde TV restarted after installing it shows blue screen wit GRUNDIG text, after that chanel 2 per seconds and then the screen is dark grey and thats it. The last time i installed bootloader, because i read this in forums, and I think that this was mistake, because after that the screen was the same - dark grey. Before that I tryed SX_NDLNA_50_737_3 and SX_NDLNA_100_737_3, but nothing. Is that any way to erase allthing and then to start install the software. If you can help me to resolve this problem i will be very thаnkfull. Have a nice day.
Moement
20.03.2020
Hallo thommyX,
hast du eine Idee zu meinem oben beschriebenen Problem? Wäre dir sehr dankbar, wenn du mir auch die passende Software zusenden könntest. Bin wie gesagt nicht sicher, ob ich die richtige genommen habe. Danke dir!
LG Moement
9.213
660
Unterwegs im Postfach
Moement
20.03.2020
Vielen Dank thommyX, er läuft wieder! :D
9.213
660
Glückwunsch.
dsp_83
03.03.2020
7
Hy ThommyX, is there any chance to repair my TV or it need a specialist.
9.213
660
If you tried different sticks and also formatted FAT32 and the SS20 is not accepted, then this is only possible with the ISP tool.
dsp_83
03.03.2020
7
Ok. Thank you
Thema: Grundig 40 VLE8042
Philips 55OLED803/56 Main 714G8465-MOG-B01-005K Not started
40 GFF 6900B nur logo
grundig ZG2190R-22 057T50A03 CHASIS NX screen damaged
40 VLE 6421 BL, no picture after software upgrade
Sony KD-55XE8096, lightning strikes
