Bauknecht Frankfurt 1600 Noise (Bearings?)
Diskutiere Bauknecht Frankfurt 1600 Noise (Bearings?) im Forum Reparatur Waschmaschine im Bereich Reparaturtipps weiße Ware - Hersteller: Bauknecht Typenbezeichnung: Frankfurt 1600 E-Nummer: 8583 601 72000 kurze Fehlerbeschreibung (2-3 Worte): Noise (Bearings?) Meine...
TonyMK
14.08.2011
15
Good morning all,
Could someone please help me with this Bauknecht washing machine?
There is a noise, especially loud when it is in centrifugal mode. I suspect it is the bearing ball. According to the schema there are two bearings:
941 0 4812 520 28003 Kugellager Agg. 2 6306
941 1 4812 520 28005 Kugellager Agg. 2 6304
No fault indication on the display panel.
Any advice?
Tony
TonyMK
14.08.2011
15
Hello Flumer,
It is indeed the right product number, I have the manual (see attached bmp file)
. I bought it 7 years ago in BE.
I looked your prevoius reply on changing the bearing on similar model. Thank you for pointing to this.
I think faulty bearing is the origin of the noise. Do you think I should change both 6306 an 6304? What about the seal ring 953 0 4812 530 68001 Wellendichtring V 40 A? Do I need to change it too?
Thank you in advance.
Best,
Tony
1.805
Hello anew,
... yes, you have change both bearings and the seal ring V 40 A, too !
The seal ring V 40 A is to glue in place
Look at my previous link;
sorry this tread is in german, you have to translate it !
But the photos and drawings there speaks for itself
Greetings flumer :lol:
For Karmavoting left in our bulletin board [+1] would give me great pleasure
TonyMK
14.08.2011
15
Dear Flumer,
I took out the drum, but I'm stuck! Can't go any further. I unscrewed four large bolts on the side of the drum, but cannot take out anything. Here's picture of the drum.
Could you please (or anyone) help me wit this?
Tony
TonyMK
14.08.2011
15
OK, I see I should use a puller
TonyMK
14.08.2011
15
Dear flumer,
Here's my progress on Bauknecht Frankfurt 1600:
The bearings have been replaced and I'm just about to mount back everything on the drum.
However, I have a question about the seal. The seal is inside the drum, on the axle, and I cannot replace it unless I open the drum, that I want to avoid.
would it be ok if I leave it like that? I mean, only bearings replaced. What could go wrong? I'm afraid I cannot open the drum for the fear I will have leaks afterwards.
Thanks a lot for answering.
TonyMK
14.08.2011
15
WaMa repaired! Thanks for advice & support.
Good luck!
1.805
Hello,
thank you for your positive feetback
Greetings flumer
Thema: Bauknecht Frankfurt 1600 Noise (Bearings?)
Bauknecht Frankfurt 1600 No spinning
Bauknecht Frankfurt 1600 Fehler F7; F11
Whirlpool AWZ7813 Noise in the middle of the cycle
AEG AEG Lavamat 13.50 update jubi_line Waterleak on ball bea
