Philips 55OLED803/56 Main 714G8465-MOG-B01-005K Not started
Diskutiere Philips 55OLED803/56 Main 714G8465-MOG-B01-005K Not started im Forum Reparatur von LCD Plasma Fernsehern sowie Beamer im Bereich Reparaturtips braune Ware - Good afternoon TV Philips 55OLED803/56 TPM18.1A LA Main 714G8465-MOG-B01-005K Processor MT5596 Graphics NT72334 EMMC KLMAG1JETD-B041 Symptoms...
ARSVG
21.01.2024
14
8
RFT Meister
Hersteller
Typenbezeichnung
Kurze Fehlerbeschreibung
Not started
Chassi
TPM18.1A LA
Meine Messgeräte
  1. Analog/Digital Voltmeter
  2. Oszilloskop
Schaltbild vorhanden?
Ja, als PDF
Good afternoon
TPM18.1A LA
Processor MT5596
Graphics NT72334
Symptoms:
After plugging it into the outlet, after 10 seconds the LED starts blinking idiotically. Doesn't react to anything.
I checked the voltage on the main.
In this state there is
1V for processor
3.3V
5V
Quartz MT5596 works
Mine seems to be in a Standby state
The owner said what happened after the power surge.
When you plug it in for the first time, the mine makes an attempt to start. All voltages except NT72334 are raised for 10 seconds.
There is no Enable for it, the queue does not reach it.
A short exchange appears on EMMC.
After that everything stops.
The LED receives a short pulse, so it blinks idiotically.
Main consumption at startup is 350 mA. After trying, zero.
There is no short circuit anywhere.
I think it has the EMMC firmware issure.
Can you help me with EMMC dump please.
Thank you.
tik-tak
20.12.2006
1.213
45
Hi Bruder,
wo ist Bootlog bitte?
Sonst bitte dein eMMC Dump hochladen und zeigen.
ARSVG
21.01.2024
14
8
RFT Meister
Hi,
Thank you.
Here is it...
  • 0124 protocol.txt
ARSVG
21.01.2024
14
8
RFT Meister
I understand its not EMMC issue.
tik-tak
20.12.2006
1.213
45
Wo ist ihr eMMc Dump?
Bootlog komplett?
ARSVG
21.01.2024
14
8
RFT Meister
Yes, I have got it (EMMC full dump).
On my computer.
tik-tak
20.12.2006
1.213
45
Dann lade hoch und gib mir Link.
Sonst dein Bootlog komplett?
HermannS
HermannS
01.10.2016
2.794
194
The protocol says "TconError has detected". It doesn't get any clearer than that. I suggest you don't waste any time hunting down software failures.
Miata3de
11.09.2020
339
84
ich bin jetzt nicht der TV fachmann, aber das log zeigt doch ganz eindeutig
after_ui1_raw_data_1[17]_2[17]_3[17]=0x61 0x61 0x61[CMain 1070][OLED Tcon error handle]display_techonlogy = 1
[CMain 1079][OLED Tcon error handle]EEPROM_TCON_ERROR_COUNT=3.
[CMain 1082][OLED Tcon error handle]Go into protection mode.
in den zeilen 384 bis 387
und am ende
°T8032 vSetTimer°(TconError has detected, Blinking the Led
Also Tcon meldet fehler, ob das jetzt "nur" das Tcon ist, oder das Display entzieht sich meiner kenntnis
edit:
@HermannS war schneller
ARSVG
21.01.2024
14
8
RFT Meister
Yes, I have received it on the table, without of panel. Only main board.
I am going to get it again with all devices connected.
tik-tak
20.12.2006
1.213
45
Bruder,
Bitte lade dein eMMc Dump hoch und gib mir Link, Ok?
ARSVG
21.01.2024
14
8
RFT Meister
I just took the same protocol, but all devices have been connected.
I guess it's the NT problem. Doesn't it?
  • 0124 protocol2 full.txt
tik-tak
20.12.2006
1.213
45
Erst bitte eMMC Dump hochladen und Link mir geben.
HermannS
HermannS
01.10.2016
2.794
194
tik-tak will nur ohne Arbeit ein eMMC Dump abgreifen und gar nicht den Fehler finden
tik-tak
20.12.2006
1.213
45
Ohne eMMc Dump keine Hilfe.
ARSVG
21.01.2024
14
8
RFT Meister
Hi,
later.
I need time to prepare it for upload.
tik-tak
20.12.2006
1.213
45
Also gibst mir dein Dump oder nicht?
Letztes mal Frage dich nett.
HermannS
HermannS
01.10.2016
2.794
194
The emmc dump has no relation to the failure. You are wasting your time.
Thema: Philips 55OLED803/56 Main 714G8465-MOG-B01-005K Not started
Sony KD-55XE8096, lightning strikes
Miele G6360SCVi Slide Shutter Fault, motor not having control signal
Philips 55OLED903/12 TV blinks one long and 2 short
Grundig Grundig 39 VLE 945 BL The edge LEDs backlight flashed twice and then dark.
TV Grundig 55 VLE 9270 BL - Problem
