Philips 55OLED803/56 Main 714G8465-MOG-B01-005K Not started
Diskutiere Philips 55OLED803/56 Main 714G8465-MOG-B01-005K Not started im Forum Reparatur von LCD Plasma Fernsehern sowie Beamer im Bereich Reparaturtips braune Ware - Good afternoon TV Philips 55OLED803/56 TPM18.1A LA Main 714G8465-MOG-B01-005K Processor MT5596 Graphics NT72334 EMMC KLMAG1JETD-B041 Symptoms...
ARSVG
21.01.2024
14
8
RFT Meister
Thank you. I need NVM.EED to unlock main board.
tik-tak
20.12.2006
1.213
45
Ich brauche dein eMMc Dump.
ARSVG
21.01.2024
14
8
RFT Meister
For what do you need my dump?
tik-tak
20.12.2006
1.213
45
Ich will meins mit deinem Dump fixen.
Also willst mir nicht helfen?
Schade schade....
HermannS
HermannS
01.10.2016
2.794
194
:happy: Help is not offered here unless you give something. Lovely, just lovely.
ARSVG
21.01.2024
14
8
RFT Meister
Hi. I think I need to cut R3348 for check main before NVM.EED correction
This resistor corresponds ERROR DETECTION signal.
What do you think?
Can you help me to found out NVM.EED?
Thank you.
ARSVG
21.01.2024
14
8
RFT Meister
Hi,
Thank you everybody for your help.
It's sorted out.
Obviously I can't give tik-tak full dump.
It's need to clear from owner's personal dates.
It's my time.
But if you need some areas without of the keys sent me request with addresses.
Good luck!
coburg1992
05.02.2024
Hi,
It's sorted out.
It's my time.
Good luck!
Hey, unfortunately I can't write to you privately and wanted to ask if you could help me. I have the same problem, the Phillips logo shows up then it goes away and ambilight is on.Remote control responds so standby flashes when button is pressed. I wrote a post somewhere else that said you could give me a tip on how to unlock it. I would be very grateful for the help.
HermannS
HermannS
01.10.2016
2.794
194
So what was the solution here exactly?
ARSVG
21.01.2024
14
8
RFT Meister
Hi,
But you don't have the same problem.
Anyway, you need to attach your protocol here to help you.
V
Vagner1991
19.04.2024
In my case - unlocking.
Hello, can you tell me, how do you unlock? My 55oled855 has a broken 24 v line in the PSU. I changed the PSU and now my Philips logo come on. After a few seconds the logo leave and the led in front Beginns flashing. I have the upgrsde_loader.upg from Philips direct. It come "upgrade in process" but after 20 minutes, the led is also flashing. The bootlog say Tcon error. I think the Tcon oder Mainboard is blocked bei software, because the 24 v fault bevore.
The fuses of the Tcon are all good and I didn't find any short on the Tcon.
Thanks a lot
666
LG Thomas
  • scc1910047v01-20210630074427 EED OLED.pdf
666
Glückwunsch. Manchmal kannst so einfach sein.
LG Thomas
Thema: Philips 55OLED803/56 Main 714G8465-MOG-B01-005K Not started
Sony KD-55XE8096, lightning strikes
Miele G6360SCVi Slide Shutter Fault, motor not having control signal
Philips 55OLED903/12 TV blinks one long and 2 short
Grundig Grundig 39 VLE 945 BL The edge LEDs backlight flashed twice and then dark.
TV Grundig 55 VLE 9270 BL - Problem
