Thomson ICC20 errorcode 26 - please help me
Diskutiere Thomson ICC20 errorcode 26 - please help me im Forum Reparatur Fernseher und TV Geräte im Bereich Reparaturtips braune Ware - Hersteller: Thomson Typenbezeichnung: 32WX410S Chassi: ICC20 Vorhandene...
Plex
08.10.2005
13
Hersteller: Thomson
Chassi: ICC20
Vorhandene Messgeräte: Keine
Schaltbild vorhanden: Ja
Hello
I hope somebody can help me in english in here...
My Thomson 32TX410S have allways had some failure, even since i bought is as new. The TV runs for weeks without problem, but suddenly it drops all tv channels, and the TV starts with asking country, and then the channel search starts. Sometimes there is 2-3 month between the drop, and other times 2-3 times a week!
But last day it took a long to start, and then all the geometry settings where dropped :evil:
In service mode I can see alot of code 26 failures. What does it mean, and how can I repair it?
Today I wont start, and the led is flashing code 26. Sometimes it starts...
Will I have to spend all my money on a new tv?? :(
Hope somebody will help my.
Thanks you
Plex
08.10.2005
13
The sw version is V1.30, if it matters... Config WT-VN-- 0004
EM2-Gott
Hello,
my english is not very good, but I will try to help you...
The newest Software is 1.32
The Errorcode 26 is no longer available in this version
But the "dropping of your channels" is a problem of the EEPROM (Memory)
benedikt2
19.08.2005
1.406
okay errorcode 26:
check all C's in your powersupply.especially those, which are next to transistors.
then make a G2-alignment.
servicemenu->video-> g2 alignment
the screen-lines have to be hardly visible
p.s. 30seconds are ok, till appearing with picture....
Loosing memory:
very bad. EEPROM ist damaged?
Plex
08.10.2005
13
benedikt2 schrieb:
okay errorcode 26:
Loosing memory:
Hello... Thank you for your reply :)
I have ajusted G2 a bit down, and now it starts everytime so far. What does the G2 have in commen with G2?
As I told all my geometry and color settings where lost, and I've tried ajusting them. Geometry is pretty okay I think, but I'm not sure about the colors. Is there any guide on the net describing how to do it step by step?
Thank you
benedikt2
19.08.2005
1.406
"What does the G2 have in commen with G2?"
-sorry, i dont understand....
"Is there any guide on the net describing how to do it step by step?"
-normally not.
you need a servicemanual
(technical services , not for customers). maybe you find it. good luck!
Plex
08.10.2005
13
-normally not.
Arg sorry.. I ment what has the G2 in commen with the errorcode 26?
I have a service manuel in pdf.
Thank you for your help
Have a nice day
benedikt2
19.08.2005
1.406
26-picturetube isn't heat up properly.
rising up G2 helps to heat the tube earlier.
put it to screenlines to a level, that you can hardly see it in videotext, or when you switch to AV.
i think ist better to align G2 a little bit higher ,than thomson wants to...
but not to high, than ist won't work...
did I help you?
Plex
08.10.2005
13
It's dead
did I help you?
Hello
The problem is getting worse... Now I wont start in service mode even. Only efter 10 times. I've tried rasing G2, but I don't help at all.
Is't my powersuply there's getting weak?
Plex
08.10.2005
13
benedikt2 schrieb:
okay errorcode 26:
Can you tell me how many that is?
The TV wont start now, and is flashing error 26. After 10 times try, it starts. Raising G2 doesn't help...
Thanks
benedikt2
19.08.2005
1.406
G2 is not too high?
put it to a level, where you can see screenlines , than turn it a little bit lower. normally that ist ok.
does it help to heat some Cs in your Powersupply?
you can use a hairdryer, or something like that.
Plex
08.10.2005
13
benedikt2 schrieb:
G2 is not too high?
I thought G2 was to high also, and I have adjusted it a bit down, but it doesn't help. But I the TV starts if adjusting G2 while the TV is on (flashing error code)?? I don't understand it... If I turn it off right after, I wont start again.
I'll try to heat the Cs in the powersuply...
I'll be back with the results 8) And I hope it's good results :)
Thanks alot
Plex
08.10.2005
13
em2-gott schrieb:
Change the Software to 1.32 - no comment!
Hrmm okay... Is the eprom flashable (eeprom), or do I have to replace it?
With other words, how to do?
Thanks
Plex
08.10.2005
13
em2-gott schrieb:
The software is a normal spare part - no flashing.
Okay thanks alot :)
Do you know any online store selling the sparepart?
Can you explain why V 1.32 fixes the problem?
EM2-Gott
One Shop is here http://www.fernseh-maul.de/Online_Shop/online_shop.html
But their are two versions of the software-ic (IR002)
35701490 (the pins are at the long side of the IC)
1079164B (the pins are at the short side of the IC)
You have the check the IC befor you order.
I told you, that the errorcode 26 doesn`t exist in version 1.32
joschi
23.05.2005
1.761
93
The englishmen do not use the name "G2" - they say: Screen!
Plex
08.10.2005
13
Thank you (everybody) for your help, I'm very gratefull :D
I've just contacted my dealer, and he will pay for the new software even if the tv is nearly 3 years old. I'll just have to replace it myself.
Even an englishman knows what G2 is
:lol: :lol:
Vielen dank
joschi
23.05.2005
1.761
93
there is a coil Pos: LL200 in the near of the DST in serial for picture-tupe-heating. remove some windings and i promise you the set will run.
Thema: Thomson ICC20 errorcode 26 - please help me
grundig ZG2190R-22 057T50A03 CHASIS NX screen damaged
Philips 55OLED803/56 Main 714G8465-MOG-B01-005K Not started
Sony KD-55XE8096, lightning strikes
Philips 55OLED903/12 TV blinks one long and 2 short
TV Grundig 55 VLE 9270 BL - Problem
