Sony KV-X2101D
Diskutiere Sony KV-X2101D im Forum Reparatur Fernseher und TV Geräte im Bereich Reparaturtips braune Ware - Hallo ich habe auch ein Problem mit meinem Sony KV-X2101D. (keinBild & LED blinkt 13 mal) Habe vieles gelezen hier, aber mein deutch is nicht so...
Jamie
29.05.2005
Habe vieles gelezen hier, aber mein deutch is nicht so sehr good :(
Hoffe mir kann jemand das alles erklaren in englisch ?
was ich machen must mit desen fehler.
fielen dank Jamie
oscillator909
oscillator909
09.11.2003
3.422
69
Hello,
in Sony television sets are often problems with "cold" or "bad" soldering.
Look at the main chassis in the power & deflection parts for this, also look for bad soldering in the tuner-box.
if you have a little bit "luck", this will fix your unit !
greetings
Jamie
29.05.2005
oscillator909 schrieb:
Hello,
greetings
Ok thanks a lott for this. I go see if this wil work then. I will let you know when it is done.
greats Jamie
Jamie
29.05.2005
Hello oscillator909,
i have done all the things you told me to do :) However i still have the same problem :? I mean i have checkt it all and also heated all the solderingpoints again so it would be ok after my thinking. But i also have read all the topics again to over al the problems from Sony kv-x2101d.
And i could see that there where more problems to. And from one "tom1960" he sended an email to some people whit more help where to look exactly. But i also tried to contact him. but i just think that i do something wrong here ? Or maybe he doesn't understand englisch ? I just need more help with this. So please anyone i do not understand it anymore for now :(
thanks already for everything Jamie
Alde
Alde
04.09.2003
3.825
42
Hallo Jamie,
Is on the Tuner Box "Made in Spain" written??
So put him out , open him and solder all points new.
Mainly the Ground Points and IC TSA...
Greets Alde
Jamie
29.05.2005
Hello,
This iss al it sais: BTP-EC411 8-598-045-01
SONY Espana G EA6A24
So yes is made in spain. And then you say from "put him out" So you mean then take it of the print and then open it ? Because for now i have only solder over all the points on the print. And thats not working. So then i have to look inside to like you say. I will try this. Thanks for this, and i will let you now if it will work :wink:
i also have to learn a lott here. But well i am stil in my studie for learning elektronica.
greats Jamie
Alde
Alde
04.09.2003
3.825
42
And be carefull - the solder points are very small....
The Chassis is BE 3 B from Sony.
I think the problem is done after soldering the Tuner!
Jamie
29.05.2005
Hi i was really hoping that this would sold the problem. And yes i also did see that the points where very small, so i have let someone else do it for me. And now that everything is back in. Stil the same problem :cry: (keinBild & LED blinkt 13 mal) Maybe there is an other solution for it to ? i mean i can only try al the solutions that you are giving me here. And yes i do like it to because i learn from it to :wink: And i also really like this site a lott, because till now this is the only one where you can find a lott information from many things.
Thema: Sony KV-X2101D
SONY KDL65-W855C Startet nicht...
NEC NP-M271XG Status LED 6X blinken
Bosch maxx 6 Bosch maxx 6 läuft nicht an
SONY fwl/kdl - 65w855c Nachdem Einschalten leuchtet unten in der mitte am Rand eine weiße LED kurz auf und geht wieder aus.
Sony KDL-32W5800 Memory Stick für SW-Update lässt sich nicht formatieren
