Problem with Grundig T51-640 TV
Diskutiere Problem with Grundig T51-640 TV im Forum Reparatur Fernseher und TV Geräte im Bereich Reparaturtips braune Ware - Your phpBB Version: PHP Version: MySQL Version: Your phpBB Type: Standard phpBB...
V
vasilescu_marius
04.09.2005
Your phpBB Version:
PHP Version:
MySQL Version:
Your phpBB Type: Standard phpBB (also called Vanilla)
Schaltbild vorhanden: No
Your knowledge: Beginner
Description and Message:
Hello everybody! I am very sorry i don`t speak Deutch very good, but i hope you spaek English. I have a big problem with my Grundig T51-640 TV. It`s pretty old indeed but i still like it very much.The problem is that after one of my smaller cousin played with the remote control it changed the position of the on screen display so much to right, that i can`t use the menu, i only have the posibility to reglate the image from the special butons, and what is worse i can`t adjust the level of the volume ,!!!, over a very low limit.Enough crying, i think the problem can be solved by a combination of keys from the remote control(something like the password diabling combinbation), wich i have been looking for_on the whole internet, manuals and so on, but i didn`t found out anything.I hope somebody can help me! Thank you very much!
O
ohmxxl
16.02.2005
279
grundig
Hi friend,
you can try this:
press the following buttons on your remote-control:
cursor right, cursor left, cursor up, cursor down
then you are in the menue, if this is not the right way, than you can try the following numer: 7038
Greetings ohmxxl
V
vasilescu_marius
04.09.2005
Thank you for your reply. I solved the problem by entering the television`s speciol hotel mode menu, by pressing i taste on the remote controll, while opening the tv.From there i was able to adjust my OSD position and disable the hotel mode.
Thema: Problem with Grundig T51-640 TV
Philips 55OLED903/12 TV blinks one long and 2 short
TV Grundig 55 VLE 9270 BL - Problem
Grundig Grundig 39 VLE 945 BL The edge LEDs backlight flashed twice and then dark.
Grundig 43 GUB 8852
nur kurz beim Booten von Grundig 32 VLE 6325 BG vom Grundig Screen
