O
oobabeloo
- 14.09.2018
- 6
- Einsteiger
Hersteller: Philips
Typenbezeichnung: 37PFL9604H/12
Inverter: DPS-298CP-A
Chassi: Q549.2LE
kurze Fehlerbeschreibung (2-3 Worte): backlight switch off after a few minutes
Hi,
My TV (Philips 37PFL9604, chassis Q549.2LE) has an annoying backlight issue since a few days.
It will power up flawlessly but, after a certain amount of time, the backlight will switch off for a second, then switch on again. It will happen a few time until the screen goes black totally.
When the backlights are on, I cannot see any dimming or artefact on the screen, thus I would not bet on a CCFL issue. The TV has been used (display on) for a bit more than 5000hours.
I used a flashlight to check that the image was still present and it was the case and I also changed the 33µf and 47µf caps connected to the backlight.
Might be worth mentionning, the ambilight will stay on when the backlight switch on and off.
Is there some other components I should have changed or some other checks I should have done ? I tried to reduce the contrast to minimum and since then, the backlight issue didn't appear back (but the display is terrible !)
I must say that I previously had another issue with the inverted/psu card (DPS-298CPA) some months ago: an annoying click could be heared after being on for a few minutes (without any backlight issue a that time). Changing the IC601 and all mosfets cured it.
Thanks for your help
Chassi: Q549.2LE
Hi,
