NKOIA 6384
Diskutiere NKOIA 6384 im Forum Reparatur Fernseher und TV Geräte im Bereich Reparaturtips braune Ware - My Nokia 6384 (ITT) television has the following problem: When I turn it on, the tv is standby (2 LED-bars). When I press P+ or P-, the LED's go...
mark_zweers
21.02.2004
When I turn it on, the tv is standby (2 LED-bars). When I press P+ or P-, the LED's go out. When I press volume + or -, the LED's go on again.
The +5V is OK, the HV transistor is OK.
Thanks for help!
Gast_1
30.04.2003
3.827
57
Hy,
check CB50 exchange to 100nF/25V
Gast_1
30.04.2003
3.827
57
Chassi Eurodiggi
CL3290TAN HITACHI
CS3290TAN HITACHI
CL3290TANX HITACHI
CL3370TA HITACHI
CL2562TA HITACHI
CL2862TA HITACHI
CL2872TA HITACHI
CL2572TA HITACHI
CS2572TA HITACHI
CS2872TA HITACHI
CL2890TANX HITACHI
6384 ITT
6384 NOKIA
7184 ITT
7184 NOKIA
7193 NOKIA
7192 ITT
7192 NOKIA
TV052 NOKIA
7291 ITT
7291 NOKIA
54394740 NOKIA
7293 NOKIA
8291 NOKIA
8293 NOKIA
8592 NOKIA
9291 NOKIA
6384TOP NOKIA
54323530 NOKIA
7194 NOKIA
SFN7291 NOKIA
SFN7294 NOKIA
SFN8294 NOKIA
SFN9291 NOKIA
SFN9294 NOKIA
7184TOP NOKIA
6384SVT OCEANIC
6384VT OCEANIC
25E7C SALORA
25E7CVT SALORA
25E7S SALORA
25E7SW SALORA
25E9C SALORA
25E9CVT SALORA
25E9F SALORA
25E9FVT SALORA
25E9S SALORA
28E7C SALORA
28E7CVT SALORA
28E7S SALORA
28E7SW SALORA
2,80E+10 SALORA
28E9C SALORA
28E9CVT SALORA
28E9F SALORA
28E9FVT SALORA
28E9S SALORA
33E9C SALORA
33E9CVT SALORA
33E9S SALORA
7018 SCHAUB LORENZ
701825 LUXOR
7192PIP NOKIA
7192PIPNICAM NOKIA
7192PIPOCEANIC NOKIA
2,80E+08 SALORA
Luke
Luke
23.11.2003
846
Hi,
You might have dry capacitors in your primer power supply! Have you ever tried to heat them up in order to see whether it works then? If it works after heat you should change all electrolyte capacitors in the power supply.
Good luck luke
Thema: NKOIA 6384
Grundig Grundig 39 VLE 945 BL The edge LEDs backlight flashed twice and then dark.
Grundig 43 GUB 8852
Grundig 32 VLE 4720 BN kein Bild nach Update
Miele WDB030 WCS W1 CLASIC F20
grundig 40 vle 6420 bh only logo sometimes and led flash
