LG 42LV375S Lines in picture
Diskutiere LG 42LV375S Lines in picture im Forum Reparatur von LCD Plasma Fernsehern sowie Beamer im Bereich Reparaturtips braune Ware - Hersteller: LG Typenbezeichnung: 42LV375S Inverter: Chassi: LD12B kurze Fehlerbeschreibung (2-3 Worte): Lines in picture Meine Messgeräte...
mentall
mentall
18.11.2015
Hersteller: LG
Chassi: LD12B
Ja, als PDF
Hello all, i have an issue with LG 42LV375S, main board died and i have replace it, but after starting tv there was some kind of interference trough picture, i was wondering did any one have issue like this and if any one knows a solution for this problem...
Thnx in advance....
HermannS
HermannS
01.10.2016
2.786
193
This problem looks digital. The distortion is perfectly regular. Assuming that the TV worked fine before the main board swap and the spare part is an exact match, I can only suggest two possible failures: the "new" (I guess it is used) board has a defect or the LVDS cable has some trouble where the latter is less likely. However, those are the components you've touched, so it has to be there.
I'd also check all DC-DC regulators on the main board for ripple, just to be sure.
Thema: LG 42LV375S Lines in picture
Sony KD-55XE8096, lightning strikes
Philips 55OLED903/12 TV blinks one long and 2 short
Fujitsu Siemens B17-1 wie öffne ich monitor Gehäuse
Miele G6360SCVi Slide Shutter Fault, motor not having control signal
Grundig Grundig 39 VLE 945 BL The edge LEDs backlight flashed twice and then dark.
